We are having a starting issue with my 2017 R21. About 1 of 50 times it will refuse to start. I get no beeps when key is turned. All other electrical works fine, however and motor starts fine once motor turns over. Obviously the Boat was in neutral and the emergency switch/lanyard was checked and ruled out each time. Any ideas of what should be fixed on this would be appreciated, especially if you have seen this before. Thanks!
Summer 2019-Previous owner had same issue. Service did not fully resolve the matter but identified that it may be the main wiring harness.
Oct 9, 2019-Stopped boat to fill ballasts. Turned boat off for 15 min. Would not start until mechanic suggested on the phone that separating and re-attaching main wiring harness. Then boat beeped twice and started right up.
May 24, 2020-After boat sat for 2 hours for kids to swim, the boat did not start. Finally started by “squeezing” harness while turning key (after more than an hour of trying to figure it out.)
June 6, 2020-After boat sat for 1 hr to swim boat would not start. Towed it back to lift. Nothing I tried previously worked. The boat started fine the next morning!
