Does anyone have a diagram of the wiring for the voltmeter. The boat is an 05 Tige 20V. Does it read off the battery or the alternator?
voltage guage not working
Across the top, click on the "Downloads" tab, then click "Manuals" then click on "20V Wiring diagram" It's for an 07 20V, but even though the boats are very similar, the wiring could be different.
When you say it's not working, do you mean the gauge is head or it's not showing alternator charging voltage? Have you touched a DVOM (digital volt meter) to the back of the gauge with the key on to see if you have power and ground and that they are tight.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I will take a look at the wiring diagrams on here. The gauge is dead the needle is not moving at all. Oil, temp, gas, and volt are all in one gauge on the instrument panel. The rest of them work. I took a look behind the gauge but didnt test for power. I will try it out though. Should the gauge move when I turn the key on or does the engine have to be running for it to move?Last edited by oleblue; 01-18-2010, 03:14 PM.
Well I popped the dash out and tested the wires on the back of the guage. There is a pinkish red wire that is weak only about 3 volts. I had a hard time tracing it with all the bundles of wires. Seems like it might be the problem. I looked at the wiring diagram for the 07 20v but I didnt see anything on there about the volt meter.
Originally posted by oleblue View PostWell I popped the dash out and tested the wires on the back of the guage. There is a pinkish red wire that is weak only about 3 volts. I had a hard time tracing it with all the bundles of wires. Seems like it might be the problem. I looked at the wiring diagram for the 07 20v but I didnt see anything on there about the volt meter.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Well I took the wire off the back of the gauge that was reading low voltage and replaced it with a wire that was 12volts and nothing except the taps comes on momentarily as soon as I touch the wire to the terminal. The fuel gauge normally comes up and the oil pressure just a bit when the key comes on but this time with the 12volt wire nothing. Replaced the old wire and the temp, oil, and fuel all work except the volts. Its a pinkish color wire and it splices into the wiring that goes into the back of the rpm gauge and then runs off into the big wiring harness. I looked at the wiring diagram and I found all the wires except for the wire that goes to the voltmeter.
