On the Blue Sea does it matter witch battery is connect to A or B? If I have the battery that will be connected to the alternator connected to B will it still charge the one on A, or should I swap it around?
ACR?
Yep, it's the ground wire that completes the loop to make it work.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I used 14ga. It's only used for sensing the voltage in order to open/close the ACR, doesnt carry any load. There's a small spade terminal on the front/bottom of the ACR labeled "GND" I believe.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by dougpaper View PostMike can the black ground coming off the acr be connected to the negative battery cable on either battery?
dougMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by philwsailz View Postno need to reply here; it is all covered well...
Woops, I just replied....
