So I installed a blue seas add a battery this winter. After a couple of times out my house battery was dead. Found I forgot to plug in the ground wire. Got it plugged back in.
Now I've run the boat a couple of other times and it still seems to want to drain the battery over a couple of days, then when I turn the music up it cuts off my amps. If I switch it to combine batteries it brings the power back up. I'm running a kicker 700.5, and a kicker 350.2, so I don't think I'm pulling that ridiculous amount of juice. I could be wrong though.
Is my alternator not big enough to charge both batteries? It's a 65 amp, stock on my merc 350 mpi. Or is my blue sea add a battery not working?
