Have 1 starting batt and 2 deep cycles, EIDB system (one deep cycle installed over the winter by the service dept).
At the lake Memorial Weekend, idling when a "beep" went off and the engine shut down. Started the engine back up checked all guages: the only abnormal reading was the voltage.
1. At idle, the voltage will decay slowly to below 12, then beep is heard and engine will shut down.
2. At RPMs above 1000, the voltage reading will get above 12, but not above 13.
3. I could start the engine at any time no problem.
Did some minor troubleshooting while there:
Took boat out of water, charged the batteries with onobard charger, went back out, same thing.
Disconnected the 2nd deep cycle, same thing, no difference.
Alternator? Starting Battery (2006)?
