What is the loudes setup you have heard and what was it. Was going to go with something small but decided to go all out.
crazy loud
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by wakemaker01 View PostWhat is the loudes setup you have heard and what was it. Was going to go with something small but decided to go all out.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Check out Wet Sounds and go to:
Gallery => Installations => Misc
The 11th photo shows four Pro 485's (three facing rear & one facing forward).
The first two photos for Supra are sick also. I haven't heard either but probably could if they turned it on right now.
The 2 loudest setups I've heard were Moki's pair of Pro485's and Dom's NVS's. Cant remember with ones he has, but they are the 2 driver w/horn per pod I believe.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Now I can comment on both of their set ups and both were insanely loud!!!!!Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
as im sure both of the above boats would blow mine out of the water (lol). by far the loudest thing i have ever heard/errr-felt had to be Tims wetsounds RZ4 from 300 ft it was way loud at 150 you could feal it and on the back platformabsoultley INSANE!!!!!!
i have a a little video of me on the back while its jammin i see if i can upload it.
Originally posted by Waterski-Rebel View PostWhat are those black things pointing out of the water that the boat is tied off to? Does he not have an anchor?j/k
Its some kind of anchoring system he used, they are stakes that go into the lake bottom so you dont need an anchor.Common Sense is not so Common
J/K, it's and anchoring system.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
