I installed a WS 420 and that introduced a very annoying whine to my system. It is only apparent when the key is in the 'on' position. When the key is in the Aux position, all is good.
The noise can best be described as a very high pitched whistle. Almost like a dog whistle. It is almost as high as is audible. Some older people might not hear it because it is very high. It happens with both Ipod and HU. It happens if I unplug the RCA jack from the head unit at the 420 as well.
Tim at WS said that that sort of noise usually comes from interference with the cables. I don't want to drop $60 on good cables to find out it did not fix the problem. Do most of you agree?
The 420 is grounded straight to the engine, I first had it to the battery and it did not make any difference to change it out. I have the power going right to the battery. The remote turn on wire goes from the HU to the Amp and then to the 420. Could that be it?
The original amp was a JL e6450 and was running everything, 4 interior speakers, a sub and 4 tower speakers. all gains were at their max. The sub was performing pretty poorly. I swapped it out for and Arc Audio 900.6 and it really woke the system up, especially the sub. Sweet amp, BTW.
I had this problem before and after I swapped out the amp.
