I am starting to put together my new stereo set-up and was wondering something.
When I had the 22i the second battery was in the forward storage compartment on the the left side, in the same area as the amps. The ground wire was real short.
Now that I have a v-drive and the battery is in the back and the amps will be mounted up forward, the ground wire should be short.
How do I ground the amps with the battery in back?
