how's it going guys. here's the stats- 2003 22v, clarion xmd cd player, mtx thunder4405 amp, clarion cabin speakers(?), RF t162c tower speakers(4), not sure about the sub- big kicker i think. two front cabins and two back cabins wired in series, and two pair of RF's wired in series- four pair total all wired in series. here's the problem- turn the volume up to 33 on the remote control and the amp(?) apparently kicks out, comes back on, kicks out, etc., until i turn it back down some. sounds good otherwise. is something wired or set wrong, or is that just all it's gonna do? appreciate the help.
amp kicking out............
That's pretty normal. Your amp is clipping to protect the speakers. I'd just make a mental note to back it down a bit and leave it at that., It's ok if it clips once in a while as a reminder, but do it too often, and you risk blowing your speakers.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Your description points to the amp going into protection. There are a few things that could cause the particular symptoms you are experiencing:
* The sub might be wired to an impedance that is too low for the amplifier.
* The amplifier might be clipping and going into protection due to the volume being too great
* Undervoltage / under current due to tired battery or wiring issues.
* Heat is a possiblity, but it probably would not turn off and back on as quickly as I think you are suggesting.
Check to see which subwoofer you have, and if possible let us know as much as you can about the woofer, how many voice coils, (1 or 2) what is the impedance of the voice coils... Then how is it wired to the amplifier...
If you have access to a digital multi/volt meter, check the voltage right at the amplifier with the volume turned up to the place where you are experienceing issues. What is the voltage?
Since it works good at lower volumes, it is probably nothing that a little tweaking cannot improve on. Dogbert might be on it exactly, and you might be just asking too much from the amp.
I bet we can improve your situation with a little investigation.It's not an optical illusion.
It just looks like one.....
Supreme Tigé Master
- Apr 2007
- 12007
Originally posted by lethalwillie View Posti just replaced the batteries on the boat and may still have a weak alternator that we intend to test. the new batteries crank the boat fine, but are a bit lower cca's since that was all we could find short notice. could this be the culprit??It's not an optical illusion.
