I would not crank your IPOD volume all the way up. You will introduce alot of distortion. About 3/4 of the way is the max I'd go.
Ipod volume--or lack thereof
Thanks for all the info!! I have no idea how to mess with bit rates so I'll have to dig into that a bit after I get some dam homework done
I am not using any special mixing/studio software to do anything to the music. I'm a caveman, I hit "buy it" on Itunes and I plug my Ipod to my laptop. Done. I then proceed to enjoy my music at whichever bit rate/compression/volume/etc.. that it came from Itunes. If changing the bit rate will make it sound better I'm all for that! It doesn't sound bad--just not nearly as "clean" as the CD.Other than that, Mrs. Lincoln, how was the play?
Originally posted by Tanner View PostI would not crank your IPOD volume all the way up. You will introduce alot of distortion. About 3/4 of the way is the max I'd go.
I believe that would only apply using the headphone jack.
I'm using a bottom connector/dock "line out" output and am 99% sure its unaffected by the Ipod volume control.
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Originally posted by Jason B View PostThanks for all the info!! I have no idea how to mess with bit rates so I'll have to dig into that a bit after I get some dam homework done
I am a WMP/Zune user, but I know that in iTunes, just like other programs there is probably a place or menu where you can change your preferences with regards to format and file size. The software leaves the decision up to YOU with regards to file size; you need to set it up for your needs. It does not magically come in at whatever format and bit rate iTunes decides....
If you are ripping and/or buying , but you are saving the stuff you rip and buy at 56K it will sound WAY worse than a CD. Being a caveman has its downsides.... Take the time to learn your software and set everything with regards to sound quality if sound quality is what you are after. I think many will tell you that saving and/or storing at lower than 256K is a waste of time.Last edited by philwsailz; 06-27-2008, 01:38 PM.It's not an optical illusion.
It just looks like one.....
