I just bought an 05 22V. The stereo doesn't work. There is power goning to the reciever, but it won't turn on. I guess I need to replace it. The reciever came with the boat new, I think it is a CMD3 maybe? What should i replace it with? I have read a few things that say to stay away from the CMD's, but I dont' know. Any suggestions would be awsome.
Suggestions to replace Clarion
Are you turning on your accessory switch? Most boats come wired such that the stereo gets its power from the accessory switch. In addition, it's wired to the ignition switch so that it turns off as you start the boat. There's a couple of fuses coming from the ignition switch that you may want to check as well.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
That receiver needs a constant 12v (power and memory) and a switched 12V turn-on. Also needs a ground.
Look for a yellow and a red on the back of the head unit for battery 12V.
CMD5 is what I would replace it with if you need. Should be a direct fit in the existing hole.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I know there is power going directly to the back of the reciever, but I'm not sure about the ground. What do you mean about having a 12V switch? There is a switch by the batteries where you can choose which one to use. Is that what you mean? If i turn the ignition key to the left, which i think is the accessory power, the reciever will not power up. I appreciate the help.
chpthril, I know on my system (when premium sound from Tige meant a JVC setup), it had an inline fuse for the head unit. Do you know if the newer systems also had that or was it wired right to the circuit breaker?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by wake454 View PostI know there is power going directly to the back of the reciever, but I'm not sure about the ground. What do you mean about having a 12V switch? There is a switch by the batteries where you can choose which one to use. Is that what you mean? If i turn the ignition key to the left, which i think is the accessory power, the receiver will not power up. I appreciate the help.
So, you should have 1 ground, 1 constant 12V, and one 12v that will be run through a switch.
Originally posted by dogbert View Postchpthril, I know on my system (when premium sound from Tige meant a JVC setup), it had an inline fuse for the head unit. Do you know if the newer systems also had that or was it wired right to the circuit breaker?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Here is a link to TMC that someone has posted the installation manual for the XMD3
http://www.tmcowners.com/teamtalk/sh...ad.php?t=14652Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
