How do you test an amp to see if it is working?
Another question
Most amp have a green and red light light. Green light indicates it's got power, ground, remote turn-on, and typically means everything with the amp is working correctly. Red light indicates problem. No light could be no power, ground, or remote turn-on, or an amp fuse is blown.
Do you have a suspected amp problem? what are the symptoms.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I guess you could power one up with a jump box , and extra set of signal cables, and a speaker to move from chnl to chnlMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
