Originally posted by Jeff T
View Post
Speaker Fuzz!
Originally posted by Jeff T View PostThanks. You mentioned in a post yesterday that I may have an issue with the fan on the back. If I just run new ground and power back to the battery, the fan will run as long as the HU is turned on or all the time? Can you clarify what you meant in that post?
The fan will run all the time with a constant 12v, so you do need to switch the power wire.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThe fan will run all the time with a constant 12v, so you do need to switch the power wire.
Originally posted by Jeff T View PostWill the HU stay on all the time as well if I don't manually turn it off or is there still a remote that is activated when I turn the key. In other words, will the key position no longer impact the HU's ability to be on or off, so if the switch is on, the HU will be on regardless of the key position and vice versa. But, I can turn off the power manually, leave the switch on, and the fan will run...which is why you want the switch to begin with.
You have to go to the battery to stop the noise, but you have to have a switch, as it is from the factory, to kill the power and stop the fan.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by dogbert View PostYes, it needs to be attached to the ground of the two components you're trying to isolate, in your case, the H/U and the 420.
Jeff,
What head unit do you have? What amps are you running?
What do you mean by fuzz? Is it a hiss, or is it more of a white noise?
Wire the turn on for the radio to an ACC switch on the dash. Mine is shared with my depthfinder.
How far are you from Hot Springs Village (Lake Ouachita). I am going fishing up there in a few weeks. I wouldn't mind helping you out.Last edited by spharis; 05-24-2008, 04:25 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Kicker ZX 650.4 (bridged) pushing 1 set of wetsounds pro80s
Kicker ZX 350.4 for deck (stock Kicker KS series)
Kicker ZX 750.1 for sub (kicker solobaric 12 L5 in vented box)
Originally posted by spharis View PostWhat do you mean by fuzz? Is it a hiss, or is it more of a white noise?White noise makes me think of the noise your tv makes when the cable goes out. It isn't like that.
Originally posted by spharis View PostHow far are you from Hot Springs Village (Lake Ouachita). I am going fishing up there in a few weeks. I wouldn't mind helping you out.
Originally posted by spharis View PostWire the turn on for the radio to an ACC switch on the dash. Mine is shared with my depthfinder.
That's what I was describing in the earlier post, spharis is just giving a suggestion as to where to wire it. If the H/U unit "turn on" is hot all the time, like straight-wired to the battery or amp, the fan will run. If not mentioned earlier, I think its the small red wire off the head unit, and the only red wire on the ignition key switch that is hot in the ACC (10 o'clock) position, other then the constant 12v.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes. Most double din and din.5 head units have those built in fans.
And usually head unit wiring is:
yellow: constant 12+ (to your battery)
red: switched 12+ (this you want on a switch)
black: ground (battery)
I wonder if the hiss you are hearing is just the powered sound that you are not used to. Most high power audio setups will have a high pitch "hiss" when the amps are powered and the volume is very low. I am unsure if this is what you hear though. It should attenuate and not be heard at listening volume.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by Jeff T View PostGotcha. So there was my confusion: The Fan will only run when the HU is ON. I was thinking that the fan will run if there was power to it, regardless if the HU was on or not. So, I just need to switch the HU.Originally posted by spharis View PostYes. Most double din and din.5 head units have those built in fans.
I wonder if the hiss you are hearing is just the powered sound that you are not used to. Most high power audio setups will have a high pitch "hiss" when the amps are powered and the volume is very low. I am unsure if this is what you hear though. It should attenuate and not be heard at listening volume.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
