So still fine with the 550.2, right?
Advice please....
Originally posted by quick View PostSo still fine with the 550.2, right?
Tell us what you want to do now. What do you want to accomplish with your system now. Do you want to upgrade/add to in, the future and do you want build an upgradable system now, or start from scratch at that time?????Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostOk, I know alot of stuff has been thrown at you in the last 2 pages, so lets back up and punt.
Cmd4a
4 Polk db651's
ws 10" sub
kicker 700.5
100a circuit breaker
and....here is what I am trying to decide in the next week.
option 1....
ws Pro 60
kicker 550.2
option 2....
ws Pro 80
kicker 550.2
I think what I really want is just some tower speakers that will be loud enough to hear at the end of the rope. Right now I have nothing....so anything will be an upgrade. I think by the time I will want anything more out of a stereo it will be the time that I will be thinking about a bigger newer Tige (1-2 years). If I do decide to upgrade to a louder system up top I will worry about it at that time.
I thank you guys for all of your help and awesome advice so far. I will need plenty more once I have everything and am totally lost as to what to do with it all
OK, the zx550.2 is perfect for either pair of wet sounds, you will not be disappointed.
There is only about $100 diff between the zx550.2 and the zx850.4, so, if you thought you would maybe add a 2nd pair of wet sound, say next winter, it may be worth upgrading the amp and wire now, and then just hang the speakers when you are ready. Or, sell the 550.2 and put that $$$ towards the new amp.
Either way, if you think you will be upgrading, spend the money on wire now.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Okay........
So I have ordered everything. Is there anywhere online that I can find some sort of a wiring diagram to hook everything up?
I ended up going with the 2channel amp and the Pro 80's. My boat doesn't have an amp currently, just the head unit and 4 speakers. I am totally lost when it comes to these things.
Thanks again for your help!
-Quick
-Quick
Reading back through, you had already ordered an amp and sub for the cabin, correct? With the addition of a 2nd amp for tower speakers, we failed to mention that the 100amp breaker will not be sufficient to carry the load of both. It makes for a much cleaner install to run only 1 set of power and ground wires for the amps, and then split off with distribution block to each amp. For this, I would recommend exchanging the breaker for a higher rated one, instead of adding a 2nd breaker and running a power and ground for each amp. Adds cost an bulk.
you will need;
20+ feet (ea) of power and ground wire (probably 0ga, but need to double check this)
circuit breaker
2 non-fused dist block (sometimes called ground dist blocks)
eyelet terminal ends for battery and breaker hook up
lots of wire ties
wire loom
12ga speaker wire
Just a few things off the top of my head this AM.Last edited by chpthril; 05-24-2008, 11:53 AM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by quick View PostWhere do I find the distribution blocks (local like best buy or radio shack...or do I have to buy online?)?
What amp circuit breaker do you recommend now?
Anyone want to buy a 100a breaker? (joking....I will return it)
Thanks,
-QuickCursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostYou can go to Best Buy get yourself one of these:
I found most of the stuff I needed for my stereo project at Best Buy. For the rest, I went to Radio Shack.
I'm with lee on this, just use an inline fuse. Best Buy has all the fuses you need.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
fused or not fused???
Will this work?
http://www.bestbuy.com/site/olspage....=1174091579002
Just 1 block...or 2?
Thanks!
Originally posted by quick View Postfused or not fused???
Will this work?
Thanks!
You will need 2.......1 for the Pos and 1 for the Neg.
Now, we need to figure what size breaker and wire.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostUn-fused IF you have the properly rated breaker at the battery. A fused d/b will be redundant.
http://www.bestbuy.com/site/olspage....1740915 79002
Any ideas on breaker size and wire?
Thanks,
-Quick
Even better http://www.electricvehiclesusa.com/category_s/126.htm
I'd say go with the: KTCBM180 180 Manual Reset Circuit Breaker.
I'd rec. 0ga amp power wire from the battery to breaker, breaker to Dist blocks, and 4ga from blocks to amps.Last edited by chpthril; 05-28-2008, 01:58 AM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
