Originally posted by Jeff T
View Post
In any instance, y-adaptor, internal connection, or switch, the electrical result is the same; the inputs are simply tied together so that both amp sections see the same signal. You will see no performance difference either way. If you are fine with what you have, leave it alone. There is no real benefit of going the other way beyond cosmetics.
