Ok here is how I see it:
Isolator will have the alt feed only going to the Alt/Comm post, B1 going to 1 battery, B2 going to 2nd.
^ You need to make sure that ONLY the Alt output is attached to the Iso Alt/Comm and nothing else as they will not have power except when the engine is running. You may need to physically follow that wire from the alt to the Iso to be sure.
Perko: "Starting" battery to B1, "House" to B2, starter cable to Comm.
Deep-cycle GND will run from the Neg (-) post on the deep-cycle to the Neg (-) post on the "Starting" battery.
Take the Original factory ON/OFF and add it on the factory ground (neg/-) in between the "Starter" battery and engine block. This will give you a simple way to disconnect both batteries from thier loads for winter storage.
Ok, that was the easy part
The next step will take some time, patience, and a little detective work, but in the end, it will pay off as you will have a simple system that is a no brain'r while on the water.
You will need to separate all the electrical loads and place them to the appropriate battery.
"Starting" battery: Engine management only.
"House" battery: Stereo/Amps, Nav lights, Blower, Bilge, Horn, Etc.
