What do you think?
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
what??????? I can't hear you!!!!!!!
I dont think the KS300.2 will do 2 485's justice
KS 300.2: Power output RMS @ 4 ohms 2 x 180 watts
*EDIT* sorry for the typoLast edited by chpthril; 02-27-2008, 08:16 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI dont think the KS300.2 will do 2 485's justice
KS 300.3: Power output RMS @ 4 ohms 2 x 180 watts"a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
"the plural of boo is booze."
Originally posted by evil0ne View PostThe KS 300.4 (I don't see a .3) is 4x90 where the KS 300.2 is 2x180 at 4ohms. They look like basically the same amp to me. I don't know the price difference nor am I a wiring expert but I thought the 2 channel was the better option. I know the 485s are 4ohm so I guess bridging the 4 channel is the only way to get the power out of that amp.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostFixed my typo, sorry. I think a 2 chnl amp is the right choice, 1 485 per chnl, but the 485's need about 300w RMS each. I think you will find that amp is not stable at 2ohms in the bridged mode. It will run hot, clip, draw a lot of current, and eventually fail IMHO."a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
Or
Cadence ZRS 3002 for the towers
http://www.infiniteelectronix.com/in...OD&ProdID=1305
and Cadence FX 5100 for interior speakers and sub
http://www.infiniteelectronix.com/in...OD&ProdID=1283
Or talk to Phil about kicker. I have heard good things about Arc but are a little price.Last edited by xpjim1; 02-27-2008, 09:42 PM.Let it be!!!
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Alright, I will jump in...
Here, for the 485's a good KICKER amp would be the 08ZX850.2, good for 295 real pounding RMS watts into each speaker.
For the 6 in boat speakers, the KICKER 08ZX650.4 will deliver around 120 watts RMS into each 4 ohm speaker.
You do not specify a subwoofer in your grocery list. Which one do you intend to use?It's not an optical illusion.
It just looks like one.....
The boat has a 12" JL. I'm not sure if it is an older W3 or worse yet. I was hoping to somehow use the 4 channels on the KS900 for the in boat and then the 550W bridged 4 ohm for the sub. Not sure how to wire 6 cabin speakers to 4 channels but I don't get paid the big bucks. Anyway, I've known this guy for a long time and I'm sure we'll figure something out."a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
Evilone, I ran Arc amps in my old boat. Used the FD4150 on a pair of 485's and it rocked. The new KS has even more power. So you will like that set up. The guys at Hydrotunes that did my RZ4 use a lot of Arc amps with our speakers. You would just parallel 2 pairs of in boats on the 2 chs running those in 2 ohm stereo. The other pair of the other chans. Then you have 6 spks on the 4 ch portion and the sub on the other portion of the 6 ch.
Tim
Wet Sounds
If I understand there would be 4 speakers running at 2ohm stereo and then the other set would be at 4ohm. It actually kind of got me thinking that I could then fade front to back (not sure when it would be important) but not sure how that would work with the WS420. Could I take the front output from the CMD5 direct to the front of the 900.6 for the bow speakers and the rear from the CMD5 to the WS-420 then to the 900.6 for the "cabin" speakers?"a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
