Tower Power help
    Tower Power help
    I have a pair of Rubicon 150's and a pair of Rubicon 350's. I have a JL audio 300-4 wired to the tower now, will this be enough power? How should I wire them in? They are not designed to run 2ohms so gonna have to have seperate chanels I think for each (4 chanel).
    The amp specs suggest 75 watts per channel into 4 channels.
    Your 150's have a power handling of 150 RMS
    Your 350's have a power handling of 400 RMS
    The amp is a little light for the application, but will work. Ideally, you want 4 pairs of wire between the amp and the speakers. One speaker per amp channel.
    A bigger amp would or could be appropriate, but if you go that route, condider two stereo amps, each sized appropriately for the speakers.
    It's not an optical illusion.
    It just looks like one.....
