Kicker amps ? (Phil??)
    I want to re amp the boat, at 1st I was thinking to continue on with the Alpine PDX line but for the components I have It doesn't seem to work.
    Here is what I have and what I want.
    Tower- Wet Sound Threesome, I need 200 RMS x2 for the Pro 80's and 300 RMS x1 for the 485.
    In boat- I have 6 wet sound XS 650 's . All need 100 RMS.
    Subs- I have 2 Wet Sound XS12's that require 500 RMS each.
    I am not sure if I want to use just 1 sub or both subs. So would like a amp that could do both if I need it to.
    I would like to keep everything @ 4 ohms if possible.
    Thanks for your help.
    Tige owner since 2006
    Sounds like a good idea. Have you talked to the folks at Wet Sounds? They offer some Amps (Cadence) just for exactly what you want to do. Don't know how the prices compare with an equivalent amp from Kicker tho, just another avenue to go.
    Maybe look at the:
    ZRS-1004 for the tower
    ZRS-7504 for the cabin's
    DCA-1000 for the 2 subs.
