So here we go. Sorry for the long winded post. There are questions scattered throughout this post along with my proposed set up. Assistance is greatly appreciated. All the Kicker stuff is just ordered (Merry Christmas to me) (Phil is a good salesman
) so I really need help determining wire and such to buy...see below.
HU: Sony CDX-R30M 52Wx4
Tower set up: (Upgrade at some point)
Speakers: 4 Sony XS-V1635X 4 ohm, 250 peak/65 RMS in 2 cans
Amp: Sony Xplod XM-2200gtx. The amp is 2 channel bridgeable.
Says 48A at 4 Ohm but has 2-40 A fuses in it
2 x 250W RMS (20Hz to 20kHz) @ 2Ohm
Wire each can to one channel on amp with 10 ga, amp will see 2 Ohm per channel
Use rear out on HU to XM-2200GTX
Can I add a second volume control on the dash to control the volume of the tower speakers independent of the cabin speakers?
Cabin set up:
Amp: Kicker ZX700.5
Speakers: 4 KM620 4 ohm, 195 peak/65 RMS
Sub: 1 SKM10 4 ohm, 300 peak/150 RMS
Use front out on HU to ZX700.5
12 ga from amp to speakers and 10 ga to sub
Wiring set up: Here is where I need the help. I've looked at some of the other threads and have a general idea.
2 batteries running into perko switch (1-2-off-all)
Not sure of alternator size
How much and what wire to buy???
Amps will be installed under stereo opposite from helm
Batteries in port rear under sun deck approximate 10’ run to stereo/amp compartment
Two options:
Run 0? to breaker (200A?) and continue with 0? to front compartment distribution block with 4? to amps
Or run 0? to breaker (200A?) and distribution block then 4? to front compartment to amps
Repeat same for ground?
Possibly rewire HU power ground. It is already on the ACC switch on the dash
Cabin set up:
Amp: Kicker ZX700.5
Two options:
