I have 4 pro 60s that the web site says are rated for 350 peak each. Im going to run a boss 4ch 1600W amp so Ill have 400 running to each speaker. do you think I will have any problems phil?
Rating help
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Originally posted by CP3 View PostI have 4 pro 60s that the web site says are rated for 350 peak each. Im going to run a boss 4ch 1600W amp so Ill have 400 running to each speaker. do you think I will have any problems phil?It's not an optical illusion.
It just looks like one.....
Ok, paper work in the box says:
RMS: 150
Continuous: 250
Peak: 300Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by CP3 View Postyour right IM wrong as usuall.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Apr 2007
- 12007
Wait a minute....
What is the RMS power handling of the speakers?
Peak power is a Marketing number; not soo good for any sort of system design or product comparison.
I like to call it the WLS spec...
When Lightning Strikes...It's not an optical illusion.
Originally posted by CP3 View Post150 is on the speakers Im not sure what the rms is on the amp im getting
http://bossaudio.com/main/436Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Apr 2007
- 12007
I see 180 watts RMS into 4 ohms times 4 channels.
That will be fine for 150 watt RMS speakers; just enough over-powered to be comfortable in my opinion.
Be sure to engage hi-pass crossovers if there are any and set the crossover frequency somewhere around and or between 70 and 100. This will remove the low frequencies and keep the tower speakers happier.It's not an optical illusion.
