My Ground setup:
Main ground goes to the battery.
Additional ground wire to reduce buzzing from taps and blower goes from amp to HU.
The fan is grounded to the amp.
With all additional grounds off (noise and fan) blower noise came through, taps, and when i turn the nav lights on theres a click. If I add the noise ground, all of that goes away. If i take it off and then add the fan directly to the amp ground, the fan comes through very loudly. Then If i put on both additional grounds, blower, taps, and nav lights go away but the fan is minimized quite a bit but I can still hear it.
Before I run a wire all the way to the battery, I have another thought. Im thinking that If I run a bigger gauge wire to reduce the noise it will take care of the fan completely. Will that work or is my common sense lying to me?
