Originally posted by chpthril
View Post
Amp cuts out
Originally posted by dogbert View PostYour amp needs to be on the same ground as your head unit. If it's not, voltage will build up between the two. This causes clicking or buzzing. In the worst case, it will eventually fry your amp. You may try installing a ground isolator (noise filter). It's designed to neutralize this.
If the H/U is close to the amp, run both the power and ground from the amp's power and ground. If not, go right to the battery (same battery as the amp)
What size wire are you running for the amp also.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by zad0030 View PostheadunitMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Power and ground for the amp both go to the battery. Im not sure what guage it is, doesnt say on the wire and I didnt install it. Our additional ground goes from the ground wire on the amp to a screw on the back of the headunit. Our dealer also spliced in the ground for the fan to that same gound.Common Sense is not so Common
Originally posted by chpthril View PostSo the 2nd ground is run from the H/U to the amp's ground? try disconnecting the H/U's original ground and see if you still have any feedback, noise, popCommon Sense is not so Common
Originally posted by zad0030 View Post. Our dealer also spliced in the ground for the fan to that same ground.Move that fan to a different ground.
Originally posted by chpthril View PostDing ding ding, no more calls please, we have a winnerMove that fan to a different ground.
Ok went out to the boat turned the key amp didnt come on. I rewired it so that the main ground for the amp goes to the battery, The fan ground goes the the amp ground and the ground we ran to reduce noise is where it started from the amp to the HU. Still doesnt work, Its hotter then hell up here and the boats been sitting in the garage the past couple days so that may be contributing. Ill try later and if it comes on Ill see where we are with the noise.Common Sense is not so Common
Went back out, it came on once out of like 20 tries. When it came on I could still hear the fan through the stereo. I never got a chance to try the blower or taps, but I assume i would not have heard it.Common Sense is not so Common
Ok went out yet again. Amp turned on more frequently this time. With all additional grounds off (noise and fan) blower noise came through, taps, and when i turn the nav lights on theres a click. If I add the noise ground all of that goes away. If i take it off and add the fan directly to the amp ground, the fan comes through very loudly. Then If i put on both additional grounds, blower, taps, and nav lights go away but the fan is minimized quite a bit but I can still hear it. Before I run a wire all the way to the battery, I have another thought. Im thinking that If I run a bigger gauge wire to reduce the noise it will take care of the fan completely. Will that work or is my common sense lying to me?Common Sense is not so Common
