i cant seem to get this whinning noise out of my speakers when the boat is running. the more gas you give it the louder it gets. the radoi isnt that bad but the xm is horrible. could it be from the rca cables running on the ground in the hull.?????? please some one cause this noise is driving me crazy.
engine noise in my speakers
I had a similar problem, every time I turned on the blower or TAPS I wouldd get feedback through the stereo, Im not sure about the engine noise.
What I did to fix it was, run a wire from the ground on your amp to the back of the headunit. This worked for us, your case is a little different but I think it should work.Common Sense is not so Common
Start with one, and see if that fixes it so you dont spend all of your time running a couple wires to find out its not the right fix. I just ran them from the ground on the amp to the mounting screw on the back of the headunit. Make sure its good and tight.
No problemCommon Sense is not so Common
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Totally common problem.
It is funny; you will find two schools of thought here; and ironically the two schools of thought do overlap.
One thing we agree on is that "chassis" or what is supposed to be zero-volt ground is a common culprit.
I will tell you if it is worse with the blower or the TAPS, it is due to "dirty" power geting to your radio head unit. Switches and blower motors cause a "dip - spike" situation on the 12-volt power wiring, and it shows up at the radio, and is then amplified in the system.
The recommendation of taking a ground wire from the radio to the amplifier's ground takes advantage of the massive power supply filter capacitors that live just inside of the amplifier.
Wait.....
We could write a book on this one, but the topic has been covered before. Check out this thread:
http://www.tigeowners.com/forum/showthread.php?t=4442
Let us know what you learn, and what additional questions you might have after reading this thread, as long as you don;t comne back and ask for popcorn or chicken....It's not an optical illusion.
It just looks like one.....
