For the stereo discussion, not the chicken. Even I can understand that one
OKay, I will start it; SP can finish.
* Try to isolate the ground loop if it is a ground loop. If unsuccessful, try a GLI on the RCA's
* GLIs are basically 1:1 unity gain or isolation transformers
* GLI's will not eliminate pops or other noise present on the power wire. The noise that started this thread COULD be a result of ground loop OR nosie on the power wire.
* Capacitors installed parallel to the battery right at the radio do a good job of eliminating noise (i.e. pops) that emanates in the power wire.
And lastly:
* We have no photographic representation of an artistic expression representative of a male chicken yet. (Maybe this weekend)
It's not an optical illusion.
It just looks like one.....
