Ok so a couple weeks ago we go out and everything is cool, stereo works just fine. Saturday we're packing the boat and i pop in the faceplate and turn on the tunes and it's cutting out, like somebody is turning it off/on/off/on. I look at he the amps and only one is on and it's cutting out.
I'm thinking the deep cycle is low so i hook up the fake-a-lake and run it for awhile and test while doing it. Seemed better and i got the other amp to come on. So i think down on charge and out we go. Ran the boat all day and the same thing happened all day. I could turn the one on for awhile but any volume would make it cut out.
Also, the amp wouldn't turn off with the head unit. After repeated off/on's it finally turned off. I know the amps aren't hot and i've checked fuses and wiring i could get to. The start batt volt gauge is showing almost 14v when running and I believe the Stinger ISO is working as it clicks when the ignition is turned on. I haven't checked the battery charge yet but plan to today.
So all you stereo guru's any thoughts on where to start looking?
