Well, I am in the process of trying to obtain gear for the eventual stereo install/upgrade. I have been quoted $150 (it is a used amp and retails new for $549) for the following amp and would like to know what other stereo folks think about this.
Nomenclature
45x4 @4 ohms, 75x4 @2 ohms, 150x2 @4 ohms bridged
& 190x1 @2 ohms bridged for sub channel
+ Microprocessor controlled
+ Remote digital bass boost gain w/led status display
+ Set and forget crossover switches on bottom plate
+ Seperate front and rear high/low/full range select switch
+ Seperate front and rear mono/stereo/full range select feature
+ Heavy duty construction
+ Thermal, DC, offset, reverse voltage, over voltage, short circuit protection
+ Output power : 45x4 @4 ohms, 75x4 @2 ohms, 150x2 @4 ohms bridged & 190x1 @2 ohms bridged for sub channel
+ Transient distortion : < .005% @4ohms
+ Frequency response: 20Hz-20Khz
+ S/N ratio(A wtg) : > 107dB
+ Bass boost : + 15dB @45Hz
+ Input sensitivity : 250mV - 2.5V
+ Crossover : 12dB stereo, 24dB mono 55Hz-5.5KHz
+ Fuse : 30A x3
+Dimensions : 16" x 8" x 2.35"
The website for this amp is: http://www.arcaudio.com/arc-05/amplifiers/xxk_5150.htm
Nomenclature
+ Fuse : 30A x3
