We're just here to help.....you part with your money
Stereo install woes
Originally posted by steves1967 View PostHey real quick- I noticed you said LOWES was closed....(guessing that is where you are getting your wire) house wire and audio wire aren't really the same thing. You want wire with hundreds of strands in it, not the house wire which has 7-8 strands in it. House wire is too stiff and after awhile will break- had it happen to me in my car a long time ago. Not sure of battery cables- but if you really want to do it right head over to your local stereo shop and get good power cable....Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jleger98 View PostNo worries. Its just money.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Hey, I was just reading my owners manual for my HU, and it states there is an orange/white lead "To lighting switch terminal"
What is that for? can this HU turn lights on/off?
Also it does state that there is a blue/white for "To system control terminal of the power amp or Auto-antenna relay control terminal (max. 300mA 12 V DC)", so that part will be fine.Reality is only an illusion that occurs due to a lack of alcohol.
Originally posted by jleger98 View PostHey, I was just reading my owners manual for my HU, and it states there is an orange/white lead "To lighting switch terminal"
The blue-wt sounds like it would work for either an amp or antenna. Like Philwsailz said, some "antenna" leads turn off when you switch to CD or AUX.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Also it does state that there is a blue/white for "To system control terminal of the power amp or Auto-antenna relay control terminal (max. 300mA 12 V DC)", so that part will be fine.Last edited by spharis; 04-17-2007, 01:44 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by dogbert View PostJust for the record, I used a premium Rockford Fosgate wiring kit. The power/ground was 2/0. The ground was only like 1' long, so I had to get a 2/0 battery cable made.
Better safe than sorry with electricity.
I always use over kill on the power wire. I realize I'm chiming in late here but I would for sure use 0 gauge. I'm using it on mine, and may have to find a bigger then 0, not sure though where to get it, but guess we will see how 0 goes.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Originally posted by Domsz06 View PostSweet, ok. I'll do that. That wouldn't create an issue with amps running hot would it? as I have one split into four amps now would it?
Dom-
You should have no overheating issue at the amps caused by your remote turn on wiring.
The biggest concern you have is messing up the HU's remote turn-on circuit. Not saying you will, but following Spharis' advice regarding using a relay is a prudent thing to do.
Most all of them will not handle a load of more than half an amp, and lots of them will only handle 300 mAIt's not an optical illusion.
It just looks like one.....
