Just spent most of yesterday installing my new system. Got all the speakers mounted, the transom remote, HU and the amps. GREAT! Then I hooked it up to the battery, hit the power and UGH!
Very little volume, and when I tried to increase the gain on the main amp, everything got all nasty. Sounded extraordinarily overmodulated, or like there was a cell phone interference, but it never went away. (I even put my cell phone in the house.)
A couple of things:
1. The entire system is independant of everything else on the boat, so I know there is no interference from that (infact nothing else on the boat is even hooked to a battery at this point.)
2. When I powered it off, waited a minute, then back on, it sounded ok, still sorta quiet, but then after about 10 seconds, the nasty sound faded back in.
3. I had the entire system hooked up in the house, off a different battery and it worked fine.
4. None of the components got jarred or anything in transit from the basement to the boat.
5. I am using a 30A relay to turn on the amps, triggered by the ACC switch.
So, any thoughts? My first thought was I had a short somewhere, but I double checked everything and it all seemed ok - nowhere for a short really.
Next I thought maybe the battery was not charged completely. I had charged it about two weeks ago, but its a used and as-yet unproven battery. I ran out of time to run in and get my meter to test it. I'll try to do that tonight.
Anyone have any other thoughts as to what the issue could be?
was really dissapointing to put a whole day into installing everything and not hearing it cranking at the end of the day.
A couple of things:
