hey, the pink cup had a NICE STIFF vodka n tonic with Kettle 1 who cares on the color it's all about what's inside
Now that's what I'm talking about.....
Hard to believe that there are 125 posts so far and you just now stuck the subs in the box. More work and less BS will get your system crankin sooner. Looks great Dom.
no probably longer. Not going to put them in the boat till it's all wired up. Getting the wire sat. Then I'll work on runing all the wire back and forth. Batteries on sat as well, as well as the boxes. So sat and sunday I'll try to wire up. Only problem is I have to be at work at 2 both days, so won't get much done. But I'll be working on it!
Originally posted by G-MONEY
Just keep in mind-a little each day and the project will get done sooner or later.
I started a cobra kit car about 13 years ago and didnt do a thing for 10 years. If I only would have done a little each day or week, Id be driving the thing by now.
i hear ya! my problem is between being a sol house owner, there is so much other stuff that I have to get done, the stereo is last to work on. And lately I haven't been feeling well, so makes for an early night
tonight's goals, are pull the sacks out, pull the old amps out, and then I hope I can run the wire and lay it along side. Also look at how I'm going to mount the rack to the side of the boat. See if I can pull the carpet off, fiberglass a board to the hull, and then put the carpet back.
