Originally posted by zad0030
View Post
Doms Stereo Thread
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
It's not an optical illusion.
It just looks like one.....
Originally posted by philwsailz View PostSome would argue, but the fuse at the amp protects the amp. The fuse at the battery protects wire, and therefore the boat, and your life.
I never thought of it that way phil. I may have to move my circuit breakers.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Supreme Tigé Master
- Apr 2007
- 12007
Originally posted by Domsz06 View Postif your just using 16 that stuff is CHEAP!! heck you can buy it at wal-mart, autozone, etc.
I was really just kidding around...It's not an optical illusion.
Originally posted by philwsailz View PostSome would argue, but the fuse at the amp protects the amp. The fuse at the battery protects the wire, and therefore the boat, and your life.
I Just had a thought. I have a 3rd battery In the garage that we dont use. And I wanted to switch the batts in the boat so that the bigger one started and only started and the other one thats not rated for starting can run everything else.Common Sense is not so Common
Originally posted by zad0030 View PostIts and MTX Thunder 4405 5-channel. Its already got a fuse so Ill probably just use that one?Maybe?
Yeah, but that fuse will only blow if the amp shorts, The fuse at the battery will kill the power running up to the amp if the wire ever shorted to a ground.....can you say fire, and then the battery explodesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostYeah, but that fuse will only blow if the amp shorts, The fuse at the battery will kill the power running up to the amp if the wire ever shorted to a ground.....can you say fire, and then the battery explodes
Supreme Tigé Master
- Apr 2007
- 12007
Originally posted by Domsz06 View PostI never thought of it that way phil. I may have to move my circuit breakers.
Power wire comes loose from the amp. No fuse. It somehow hits the ground wire, the amp, (which is grounded) or anything else that is grounded. Suddenly the power wire is not a power wire, but a glowing red hunk of copper with a bunch of flammable hydrocarbons going liquid and catching fire along the entire length... Bad enough anywhere... Picture a boat going up on the water... Sinks... Picture it going up in your garage. There goes the house.
Fuse your power wires guys.... Please... Too much at stake...It's not an optical illusion.
Originally posted by da.bell View PostBefore you do that, let me buy some stock in the company you purchase all this stuff for so I can become an instant millionair...
Fuse your power wires guys.... Please... Too much at stake...Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Originally posted by da.bell View PostLets hope he has a great insurance policy.. Do you want to hook him up??????????Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
