Doms Stereo Thread
    Originally posted by Domsz06 View Post
    it reads 3 ohms on both dvc's and they are supposed to be 2 ohm, is this blown?
    Make sure your leads are zero'ed
      I pressed the calibrate button on my machine and moved the arrow to zero, and then when I touched the leads together they read zero, so that would be good enough right?
      Originally posted by G-MONEY
        Bingo
          so the sub is fried right?
            I'll leave that for Spharis. I would think that a blown sub would be either 0ohms (short) or mega ohms (open) or some where in between but 1ohm more than spec, I dont know on a speaker
              chp's comments sound right to me... Typically a blown woofer has a much lower DCR or shows totaly open. The lower DCR can be due to a few things, burned insulation with coil turns shorted, or insulation rubbed off and shorted to other parts of the coil or the motor.
              Can I suggest something? What happens if you use a 9-volt battery and "spark" one of the coils? Will it make a popping sound? Give it a shot.
              Also, when you push on the woofer cone, right at the center, does it move, freely and quietly, or does it feel stuck? If it moves, does it make a scraping sound?
              I may PM ya; are you where you can yak on the phone right now?
              It's not an optical illusion.
              It just looks like one.....
                I am where I can talk on the phone now yes. I'm up for all options, I just know I have tried 2 different amps, and all the different ways possible to wire it and the speaker will not perform, at all, so that's where I came up with it being fried.
                  Dom-
                  Hey, just thought of something. Check resistance, (ohms) between the hot terminals for both coils. Let us know what the resistance is
                    i figured it out with Duane's help. I didn't have it wired right. It is now, and goes in the box tonight! it HITS HARD!! and the new box is in the back of the car to go into the boat for the 12's, now I just need to get home so I can work on it
                      What was the deal? Tell us; I have a few ideas what might have happened...
                      Was it in front of the amp, or the amp to speaker wiring?
                        He's got so many wires, it's easy to see how he might have missed one
                          Probably switched the wires by accident.
                            That's an understatement!
                              So now you have everything will da get his earthquake this weekend??
                                forgot about that G... I just have to make sure my boat is off the lake when it happens. I don't need a new boat so I don't need to have the lake drain because of the earthquake either.
