Doms Stereo Thread
    The polks look good.
    Now with 18 pages on this thread, I have forgotten a few things...on post #253 is that just an amp at the top of the first two pics? It has a lot of dials on it.
    Are those fuses that are visible in the pics also? I was told the fuse should be as close to the battery as possible.
    Be excellent to one another.
      the dials is an equalizer.
      they are circuit breakers. In a boat most people don't even run fuses/circuit breakers. I run them here as they are nice and close to the amps. Yes something could still short out, but not likely.
      Car you want them as close as possible, as there is metal and it's very easy to rub something raw.
      Several people on here don't even use fuses on their boats, just the one's with the amps. PPI doesn't have internal fuses, so I put them here.
      Thanks for the compliments on the Polks.
      Originally posted by G-MONEY
        look what the fed ex man brought me
        these things are TINY! that's a quarter in the pic!! I'll be putting them on the dash, right on the bottom of the window.
        Be able to monitor all my amps temps!
          picked this up to finish the job.
            here is where the charger is going. I always wondered why my carpet keeps coming unglued on the back, well it's because there is only U shape patterns of glue on the hull
              Got all the + and - run to the port side, and all most all of the remotes. Just have to hook up one more remote, and then the + and - to the relay and the port side will have power.
                I don't know what to say anymore but......... "U DA MAN"
                  What does the red wire go to?????? he he he
                    Thanks G-money. It's been one long road, and it's gonna be a night mare to clean it up and make it look pretty, but I can handle that later, gotta get it all running first, clean up second.
                    Da.bell, the red wire touch it and find out
                      Put one hand on the engine block, and lick your fingers first....
                      It's not an optical illusion.
                      It just looks like one.....
                          Bwahaha! Good one Phil!
                          Hey Dom looks like you took my velcro suggestion literally! Looks like a velcro wall! Great job man!
                            I was just going to ask what the black strips were where the carpet is cut away
                              yup the charger is going there. I think it will work nicely as the lip there will help hold some of the weight. If it doesn't work, I"ll move the battery along the wall, and that will solve the problem as the case will support the weight, and the velcro will keep it to the wall. I think it will work nicely guess we shall see.
                                was in the field for 12 hours yesterday, so couldn't post up, but here is the work from thursday!!
                                Remote wires, what a MESS!! but look, they clean up nice
