ha ha ha, the thing with sub amps is you don't need a real expensive one if you don't want to. The deal with all the expensive amps is the are like a class a, b or maybe a c, which amplifies, better, is stable at lower ohms and what not. It's a good deal But subs don't need all that, so you could buy a cheaper one.
check this out, it shows you how to wire stuff at certain ohm loads!!!
well here is what I got done tonight. All the batteries are hooked up. I ran out of power cable, so gotta go buy more of that tomorrow, and will hook the amps up sat as well as the speakers. Looks like I could hear some tunes sat or sunday
Looking good doms........ I bet you can't wait to be done.
