So i picked up one of the stinger battery isolators and the instructions for it say to install between the positive terminals of both bats (duh) with two fused leads. How important is it to have fused leads coming from each bat to the iso on a boat?
Battery Isolator ~ Part Deux
I don't see a need to fuse those POS cables. I would run my cables in wire-loom though.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
the wire might not melt but the weakest link would be destroyed with out a fuse. that is what a fuse or breaker is used for. properly-selected fuses (or other overcurrent devices) are an essential part of a power distribution system to prevent fire or damage due to overload or short-circuits.
We're talking about batteries, and charging systems, not electrical components that do require fusing. Look at your car or any other vehicle (as long as it's not a toyota), and find a fuse on the charging system that isn't direct linked to the ignition, or other electrical component; as in the wire itself is fused.
Fusing of wiring in vehicles is done because the chassis is ground....if a wire cuts, it creates an closed loop to the battery, battery overheats, then wires melt, etc......so you fuse the wiring in a car.....in a boat, there is no chasis that is always grounded. I do not find it necessary to fuse wiring in boat applications, just components.
Besides that, fusing this isolator would be very bad business if the fuses both failed. The alternator would be without the conditioner, the battery, and it would likely fail as well, if that is a 3 lug.....I don't know what style Razz has.Last edited by spharis; 03-08-2007, 08:35 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Right, on the starter.....I have a breaker on mine as well.
There's nothing on the charging system though; if a fuse blows on the charging system......could be bad for the alt. This would have the same affect as turning a battery selector switch to "off".....bye bye alt. If they did use a fuse there, then if it were my boat, I would be removing it.
Here's a good article on simple DC boat isolator and dual battery setups.
http://209.85.165.104/search?q=cache...lnk&cd=1&gl=usLast edited by spharis; 03-08-2007, 11:06 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by spharis View PostRight, on the starter.....I have a breaker on mine as well.
There's nothing on the charging system though; if a fuse blows on the charging system......could be bad for the alt. [/url]
so, the big red battery cable, the only cable on the positive side, also has a fuse and then hooks to the starter is not part of the charging system?
Obviously not because if it did i would not have smoked my altenator when i accidently reversed the polarity on the battery cables last week. I checked the fuse at the starter and it was intact. Had there been a circuit breaker inline between the battery and the starter that would not have happened. But again fuses at the isolator would not have prevented that."Call me anything you want ... Just don't call me NOBODY!
