Yes, it puts out 60x4 at 4ohm, 90x4 at 2 ohm, and 175x2 @ 4ohm when bridged.
Powering 6 speakers with 4 channel amp?
Jeff....the driver is not bridged....nothing is bridged. It just lowers the impedence of that channel to 2 ohms. Bridged just means that you are using 2 or more channels to power a single driver. Perhaps it was a bad choice of words. You would simply be wiring the channels to 2 ohms vs 4.http://www.wakeboatworld.com
[]) [] []V[] [])
Any thoughts on using this option:
http://marine.jlaudio.com/products_amps.php?amp_id=262
Specs:
-6-Channel Class-AB System Amplifier
-Absolute Symmetry Class AB Circuit
-Differential, Noise Cancelling Input Topology
-RMS Power Output:
-45 Watts x 6 Channels @ 4 Ohms
-75 Watts x 6 Channels @ 2 Ohms
-90 Watts x 3 Channels @ 8 Ohms (Bridged)
-150 Watts x 3 Channels @ 4 Ohms (Bridged)
-Variable High- / Low-Pass Filters: 50 - 200 Hz
-Adjustable Input Sensitivity: 200mV - 8V
-Bass EQ on Channels 5 & 6: 0 / 6 dB
-3 Pair RCA Stereo Inputs
-4-Channel High Level Inputs (Not Sure What This Means!)
-Channel 5&6 Sum / Discrete Input Switch (Not Sure What This Means)
-Unregulated MOSFET Switching Power Supply
-Dual N-Channel MOSFET Output Design
Specs:
-RMS Power Output:
-Dual N-Channel MOSFET Output DesignSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
High level inputs are speaker wires running to the amp to provid the signal. Speaker leads are usually high level, RCA/composite are low level. Low level gives a cleaner signal.
The 5&6 sum is most likely going to have something to do with bridging that channel for a sub. It will probably make the input signal mono so you have a constant single channel input.
And I love JL, I just don't love the price tag associated with it.http://www.wakeboatworld.com
[]) [] []V[] [])
So do you think that this will be a better option than running 4 speakers parallel out of 2 channels off of a 4 channel amp? FWIW, I can get a decent deal on one of these amps new. It is slightly more than I wanted to spend, but it falls into the range of I would do it if it is the best option.
I have the kicker 350.4 and 350.2 and I like em. I have the 4 cabin speakers parallel on 2 channels and the 2 tower speakers on the other 2 channels of the 350.4 while the sub is a dual voice coil setup to the 350.2. I wanted to seperate my cabin speakers and tower speakers by fade so I could turn up the tower speakers without blasting the people in the boat.
Plus these amps have the crossovers built in for adjustment.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
[QUOTE=spharis;39365] Low level gives a cleaner signal.
QUOTE]
Spharis,
Not to hijack, (but yes I am hijacking), Most stereo gurus seem to love having a line driver to give a high level input. Please explain what you mean by the low level being cleaner.Be excellent to one another.
Originally posted by Coach View PostPersonally for any product I say away from "Marine" Products covered in white. Amps shoud be somewhere they will not get wet. JL makes some good amps but I would stay away from the white amps. Arc, Zappco, JL, Kicker, and Crossfire (best bang for the buck) make great amps.
[QUOTE=talltigeguy;39699]Originally posted by spharis View PostLow level gives a cleaner signal.
QUOTE]
Spharis,
Line inputs on an amp run through an internal converter that take the signal down to a useable level. No sense in doing it if you have the option not to.
Info on RCAs and why they are better....note the shielding which you will not have on a speaker lead.
http://www.bcae1.com/rcacable.htm
Here's some info on line out converters, which an amp will run a speaker lead through, or you will have inline external if using speaker leads. This are generally reserved for situations where RCAs cannot be used (like an OEM head unit).
http://www.bcae1.com/loc.htmLast edited by spharis; 02-15-2007, 12:50 AM.http://www.wakeboatworld.com
[]) [] []V[] [])
