I have decided to go with the solobaric 12L5 with a kicker 750.1 pushing it. Up until now, I was planning on building my own box even though I have never built one.
Box volume requirements as per kicker's website is: 1.75-3.25 cu ft.
I wanted to use a vented box, with the vent on the front face of the box. I found this enclosure/sub package deal on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...8213&rd=1&rd=1
At first glance, I was thinking...perfect...because it is vented and carpeted. After second thought, I have some concerns. The seller claims 1.6 cu ft. The min according to kicker is 1.75. I did a little math based on the seller's demensions (13Hx18Wx16D) [and I know the box is made of 5/8ths inch MDF] and I show that the box has a little more volume than 1.6 cu ft. I think it has somewhere around 1.77-1.8ish. Either way, it is either slightly below or right at the minimum requirement for the sub.
I also found this enclosure on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
This one is a little bigger, but is made of 3/4in MDF. Overall volume, by my calculations, is just slightly bigger at around 2.1-2.2 cu ft. This enclosure does appear to have higher quality construction. Nonetheless, it is still under the MAX volume for the sub.
Now, here is where my lack of experience comes in. I don't know what effect a box's size has on the overall sound of a sub. So, the question is, would you buy one of these sub enclosures or would you build your own to maximize volume? Keep in mind the following:
1-I have zero experience building boxes and do not have the tools needed. I would have to have Lowe's or Home Depot make my cuts.
2-I have enough space in the kickpanel to build a bigger box than both of the above options to maximize box volume.
Wow. Just realized I wrote a short novel. Thanks for taking the time to read. I appreciate any feedback.
