We have an 08 22ve and the Clarion CMD5 head unit has failed. The boat also has 2 wired remotes. There are 2x Rev 10 on the tower, 1 sub and cabin area speakers. 2 Amps. We stream music via bluetooth. Should we replace the failed unit with a Wetsounds 420BT, 220 or some other option? If I understand it correctly we would not need a head unit then. If we went with the 420/220 I was thinking of installing in the glove box where the CMD 5 lived (not sure if the current hole will work or need some resizing and filler plate?). A concern is how do I kill/mute the system from the driver seat when a rider goes down so we can get regrouped? then unmute when we are back up and under way as the Clarion remotes will be inop?
We are open to other ways of addressing and updating the situation.
Thanks in advance.
Sent from my SM-G950W using Tapatalk
Thanks in advance.
