Here are my readings at different idle speeds, the volts really jump when I am around 1400 rpm or higher.
Alternator Upgrade Situation
What RPM is the charging kicking in. It looks low in the 750 RPM range, but there could be a blower running or something too. Mine starts to output heavy around 850 RPM, but my engine also idles there. There must be a blower running b/c the 1400RPM is down about .4 volts.http://www.wakeboatworld.com
[]) [] []V[] [])
Mine doesn't really kick in the full 14.4 until I am around 1600 rpm. No blower was running - battery was nearly dead - I don't know if that would make a difference or not. Mine idles at 750. I was hoping that the smaller pulley would create more power at lower rpms. Any ideas on what is going on or any suggestions?
Here is the reading at lower rpm:Attached FilesLast edited by Moki; 03-27-2007, 04:07 AM.
If it was me i'd try and use a piece of round stock aluminum and just bore a hole in the center. A machine shop could make you one for around $20 or so. If you can't find that then you could use some heavy gauge galvanized plumbing pipe and just cut to length."Call me anything you want ... Just don't call me NOBODY!
