Amp Power
    Amp Power
    I am adding a third amp to power a second pair of tower speakers. I will have a Wetsounds Syn 6 and 2 Wetsounds Syn 4’s. I believe both of my current amps receive their power from their own individual leads from the battery compartment. I am thinking about using a single lead from the battery compartment to a bus near the amps, and then branching into 3 short leads to the amps. 2600 watts will pull 216 amps at 12 volts, and #2 cable is rated to 300. Are there any issues I should concern myself with?
    At what length? To reach the batteries in the back, you are looking at about 30-35 ft at least.
      I will estimate the length in the next day or so. Is there any risk in picking up noise running the wires this way?
