ICE Module - 2017 Z3
    I successfully updated the software but had to upload via the usb port that is directly plugged into the back of the touch screen bc the AUX/USB port did not connect. Currently, I have no audio, bluetooth, aux, ipod or radio stations. Everything else functions from the screen so it leaves the ICE module. USB from the touchscreen to the ICE module is securely connected. Does anyone have a wiring diagram for the touchscreen and ICE module? Either, there is no ground, power or the ICE module is bad. Trying to avoid a 4 hour haul to the dealer for an easy fix.
    Koolaid may chime here with some helpful insights.
    Just thought I would mention, there is a dealer in Austin - your profile says "Austin". Where exactly is your boat located?
      I have used the generic Murphy’s ICE installation document to help me with a couple wiring questions:
      https://www.enovationcontrols.com/up...00-02-0976.pdf
      To be fair I usually have to pose further questions to wiser people, but I am at least prepared with more information.
