2011 rz4 stock power
    Looking to clean up my stock amp rack. Don't want to run new trunk just want to put existing 2 pair of power runs on distribution blocks. I can't see what size wire was used from factory but it doesn't fit well into the syn2 and syn-dx6 inputs. Does anyone know what they are? Looking for some simple Tpec options.
    Thanks
    Sent from my Pixel 2 using Tapatalk
    I think its either 8 or 6 gauge.
      Looks like Pacer SAE No. 4
      Assuming 4ga.
      This is what I need to clean up.
        If the insulation says 4, then that would be 4ga. Those amp are designed to accommodate 4ga. The issue is when the end is allowed to mushroom. Fresh stripped cable will fit in cleanly.
