Originally posted by chpthril
View Post
Sudden loud hissing from the front two speakers
Would the 420 cut the MA? not really, as it would go in between the MA and amps. Only needs a single RCA pair into it, to give you 3 outputs. The MA unit will still be the master unit that turns the amp and 420 on/off. Still be the portal for BT, Tuner, USB, etc (what ever the MA unit has).
I would do this, or stretch the budget and go with the MC1 now.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If you are truly limited to $300 then I would either spend $320 on the 420 because you can always upgrade the HU later if you feel you need to. Or stretch a little more for the PMX-2 and PMX-0R for $399. Problem with the MC-1 if you are trying to save liquid funds is that the remote will be another $199 on top of the $699 for the HULast edited by dj2; 06-19-2018, 01:07 AM.
Is there currently a transom remote?
R/F display remote is same price.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I guess that would be a good question, I assumed he currently had a transom remote already because he asked about the PMX-0, I never looked at that HU because the loss of a display and no xm radio functionality. I almost bought the -0R remote but opted for the -1R to have the display on the transom also.
My bad...
The MA is feeding the tower amp via RCA correct? No noise from towers right?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThe MA is feeding the tower amp via RCA correct? No noise from towers right?
Excuse me for not being too up to speed on that MA unit. I have no need or desire to ever suggest or install one, so I have not boned up on it since I dont have a need here in the shop.
Is the RCA out a full range or sub only?
If full range, then swap the RCA between the HTX-1 and HTX-6. I doubt you will ever hear that noise through the woofer, so makes it a non-issue for now.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostExcuse me for not being too up to speed on that MA unit. I have no need or desire to ever suggest or install one, so I have not boned up on it since I dont have a need here in the shop.
According to the user manual for the MA300 the RCA pair out of the head unit are "2 Channel pre-amp line level outputs" ......I'm assuming those are full audio outs then....hopefully this works...Last edited by BurnMac42; 06-20-2018, 01:02 PM.
I would not worry about this damaging the woofer. Seems like the output is there, just corrupt on that one chnl. But to the woofer and amp, it just looks like an audio signal. Good chance the low-pass setting may filter the noise and you wont hear it from the woofer.
That RCA description sounds full range. I would expect it to expressly state sub or woofer if low-pass only, or indicate its selectable full or low.
So try swapping and see. This might get you by until you are ready to make a permanent fix.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI would not worry about this damaging the woofer. Seems like the output is there, just corrupt on that one chnl. But to the woofer and amp, it just looks like an audio signal. Good chance the low-pass setting may filter the noise and you wont hear it from the woofer.
Anyone ever see this before? A HU going bad like this? At this point I'll have to get in touch with my dealer because I believe the HU is covered under the Tige warranty but I'm a little worried they won't cover it because I put the amps in aftermarket....Ideally they will just credit me the amount for a replacement MA300 and I'll order a better HU thru my dealer...if not I'm out of ideas other than changing out the HU....
So you've got an issue that is corrupting ALL the audio output on the head unit, both high and low level. OR, the issue is down stream at the amp.
thinking.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostSo you've got an issue that is corrupting ALL the audio output on the head unit, both high and low level. OR, the issue is down stream at the amp.
thinking.
This afternoon I swapped which amp was plugged into the RCA out of the HU. So instead of the Head Unit's RCA sending signal to the HTX-1 and sub, I changed it so the single HU RCA out was now sending signal to the HTX-6 hoping that the static was being caused by the L+/- and R+/- wires that I had to tap into for the KISLOC. We were hoping that the static would now shift to the sub and the filters would just ignore the static because of the sub.
Nope.
The static stayed in 3 of 6 inboats even though they were now being sent music by the RCA out of the HU. My only guess is something within the HU went bad. When this problem originally happened we were by no means pushing this system it was literally playing super soft music, parked in a cove, while my 11 month old slept on the boat. Literally mid-song all of a sudden static started coming in thru 3 speakers....
Edit:
So looking at the MA300 Manuel the Red RCA line out is the "line out right". This is the line that the static comes thru along with the right side +/-'s when it's hooked to the KISLOC. So somehow it would appear that the signal the HU sends to the right side only is bad... Not sure how that happens...
As an interim solution until I figure out the new HU could I hook up the L-/R- and R+/L+ on the KISLOC and basically eliminate the "line out right" signal from the HU? Basicallly sending the "left side out" signal thru both the left and the right of the kisloc but then at least getting a clean signal to all 6 inboats?Last edited by BurnMac42; 06-23-2018, 03:18 PM.
