So last year I installed a my Revo-12FA in the kick panel under the drivers console on my 2017 R21. One question I have is when doing the install I noticed what appeared to be a felt like material separating the back of the sub from what I assume is the starboard side bow area. Should I remove this felt material so more air gets to the back of the sub?
Revo-12FA Install
That woofer needs a very large air space behind it. Even a poorly constructed, partially sealed small cavity will impede the woofer's output. As long as the felt like material is very breathable, its not an issue. But its sounds like it could be a dense enough weave, that it could.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
