Ok so I am having a bit of a dilemma. This is my first Tige and sub placement is a bit tougher than my previous Supras. I always went with under the drivers helm and had plenty of room. With this boat this isn't an option. Just not enough space and even if you opened up the helm wall on the drivers side there would be no room to create a box due to the ballast door being located in that compartment. Soooo I am guessing placing a woofer or two into the storage locker with a ported box and venting that locker into the cabin would be the best option? It should be noted that I love a LOT of bass
. I am currently considering doing this with the Sundown ZV3 15" sub as they don't require a ton of air space and will be powering it with a soundqubed 2200.1 amp. Another question is which direction should the locker be vented? Will I lose a ton of the low end bass? Is there any other options that would be more efficient and still give me what I am looking for? I should also say that I will be leaving the WS sub in place. It has already been rewired so it provides decent bass. Just not to my liking. Thanks in advance for any help guys!
