While the RZ4 is under construction and missing its engine (long story) I've decided to move my battery bank. I'm running 4 group 31 AGM batteries. Since I upgraded batteries about 2 years ago, these have been located in the rear compartments. 1 on the port with the crank battery and 3 on the starboard side. Needless to say this was a very tight fit. While getting in there and poking around the past few days, I just don't like it. I've decided to move them to the main storage area where the amps are. Along with the batteries will be the NOCO 4 bank charger and the liquid lumens box. Because of all of these electronics, I'd like to take this opportunity the clean up the amps and other electronics in there as well. But I have a few questions...
1) what is the best way to secure these? standard battery boxes? Can they be screwed directly to the floor?
2) Anyone have a good tutorial on making an amp rack? I'd like to do this at the same time.
3) What is the best way to wire this up? The simplest way in my mind would be to run a +/- from the bank back to the distribution block next to the crank battery. But it seems like an awful waste to run the power all the way back to the distribution block and then back to the amps. Maybe not. The rear location is of course where the other accessories are ran to.
4) If any of you have large banks like this, I'd love to see some pictures of your setup. I'm not really decided on where to place the batteries in this area.
Any and all help on this is appreciated.
