I have a Wet Sounds Syn 6 amp, the inboat XS-650's are wired on channels 1 through 4. My sub is connected only to channel 5, and nothing to channel 6. My question is should the sub be wired to both channel 5 and channel 6?
Amp wiring for sub
Originally posted by Brianrzr View PostI have a Wet Sounds Syn 6 amp, the inboat XS-650's are wired on channels 1 through 4. My sub is connected only to channel 5, and nothing to channel 6. My question is should the sub be wired to both channel 5 and channel 6?
The speaker wire color just determines the woofers phase, so not nearly as important as connect to the proper chnl 5 terminal and proper chnl 6 terminal in order to have a properly bridged woofer. You will need to terminate to the chnl 6 + and chnl 5 -. Now, to be at zero phase with the in-boats, you will connect the woofer's + to chnl 6 and woofer's - to chnl 5. Inverting them puts the woofer in 180* phase to the in-boats, which sometimes works best.
You will also need to reset the amp gain for chnls 5/6 when going from single chnl to bridged mode. This presumes all other settings are correct.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
