Help: Indy Tower wiring inside of tower? 2000 22i
    I purchased the Indy Tower because of the dumb Metcraft tower that came on it. The website says it can go in the tower but there's no holes and with multiple joints there's no fishing all the way through. Who has put the wiring for Tower speakers inside the tower? Thanks in advance.
    When passing joints, you typically need to jump from above the joint to below the joint with a service loop. This sometimes require a disconnect in the middle, depending on how the tower folds. For tower feet that are not hollow to allow the wires to pass through the foot and deck into the boat, you again, have to come out of the tube above the joint/foot with service loop and then use a deck fitting of some kind. There again, this may need to be a disconnect depending on how the tower folds.
