I have found it to be useless for surfing. It raises the volume as you increase speed but you don't go fast enough surfing to make the volume change much. They should have made it adjust with RPM instead of speed. It does work pretty good at faster speeds when tubing or wakeboarding.
You can shut the auto volume off by clicking it a couple times. Has a couple settings for loudness so click it a few times to shut off completely and just adjust volume yourself as needed. Just mentioning this in case you didn't see you could shut it off. As others said works fine if getting up to cruising speeds just like a car.
