So I'm going from 4 to 6 in boats and not sure on where to put the extra 2. The boat is a 2007 22ve. Any suggestions who be great, thanks.
upgrading
The OEM spot would be under the helm for one. Cant remember where the 4th OEM spot is, cause I cant remember where the 2nd OEM spot was. Where are the current 2 in the main cabinMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Ok, so #4 would go right across from the driver above the cup holder that are under the observers seat.
Now, if you have or are planning on a sub woofer, id reconsider the under helm speaker. It would be best to be isolated from the woofer. This can be done by design of the woofer enclosure and facade. Or below and forward of the throttle is an ok spot. However, it gets close to the edge of the panel. This now needs to work in order to isolate the back of the speaker, from the front.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
With the speaker close to the edge of the side panel, you can get some rear cone output coming around the panel mixing with front cone output. Its out of phase and creates issue. You are best to build some dividers that isolate the back of the speaker.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If they are going in the OEM spots and the boat is pre-wires, then yes, id use those leads. You will have the bow pair on 2 amp chnls. and 2 pair on main cabin on the remaining 2 chnls.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If the existing 4 speakers are not currently wired to an amp, then yes, you will have to sever them from the head unit harness and rough them to the amp. There may be enough harness there to do this. Folded over and taped up in the harness loom. By that year, tige pretty much pre-wired for all options, including an amp for the in-boats. So I believe the harness was left long enough to reach the amp, even though the amp option was not installed.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
You dont want a wood enclosure sitting on the floor for starters. There are factors that will dictate whether the actual enclosure is secured to the floor or not. There are designs in which the box is secured to the facade and the facade is secured to the boat and times where the box is secured to the boat and the facade is bolted to the box.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
